Linking a set to a path
I am currently undergoing a parametric analysis of my model where I am changing the lengths of certain geometries and seeing how this effects the moduli of the material.Currently, when I attempt to define a path from which to acquire the reaction forces, the nodes used change as the geometry changes for each model. Is there any way of linking the nodes in a Path to a previously defined node set.
Many Thanks
RE: Linking a set to a path
Create the node set based on the geometry not the nodes.  Select and edge, face or point.  Then when you remesh it will remap to the new nodes.  I hope this helps.
Rob Stupplebeen
