Old Material Spec A263 Gr 0
Does anyone have access to A263 spec published in 1950's? I am dealing with some vessels built in 1958. The shell plates were lined or cladded with 405SS per A263 Gr 0. Based on some details on drawing, I think the the liners were attached to the base metal by spot welding.
RE: Old Material Spec A263 Gr 0
Bend Test
Grade 0, Type 405, cold bend 180 degrees
and tension test
Thanks.
Based on your reading, did A263 Gr 0 1952 require integrally and continuously bonded cladding?
Back in those days we had several problems with CS clad with SS.
