maximum pipe deflection
Hi all
Do you know why all most recommend about maximum pipe deflection is 12.5 mm
RE: maximum pipe deflection
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
If you have a 20 foot span, 1/2 inch is equal to L/240, a common limit for beam deflection where too much liquid pooling is avoided.
L/180 is a typical deflection limit for beams under motion sensitive floors and equipment.
L/360 is a typical maximum deflection limit for normal use floors.
ht
I guess aesthetics, stability or dynamics, as well as effects on specific coatings or linings involved might also be considerations in some at least local stipulations with regard to mid-span deflection.
It creates far fewer questions if the deflection is kept below limits where people don't really notice it.
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
Team Members
NOTE: In most cases deflection will determine the span length. These span lengths are acceptable for horizontal runs of carbon, alloy or stainless steel pipe with the same O.D., equal or greater pipe wall thickness and for temperatures up to 750 degrees Fahrenheit. Piping with concentrated weights and risers require lesser span lengths and then allowables for stress and suggested deflection given in B31.1 Power Piping Code govern.
Span lengths may be found by inserting data in the unshaded areas.
L S THILL
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
"All the world is a Spring"
All opinions expressed here are my own and not my company's.
