Using Manway as Nozzle
We have a 24" manway with standard flanges per ANSI B16.5 in a 8840mm dia. process column.Our Process engineers want to do some modification, for which they need to use this manway as an inlet nozzle by cutting a 16" opening in the blind flange and connecting it with a 16" line.
However, this doesn't seem to be feasible from strength considerations, as ASME code doesn't seem to allow it(Per UG-39, Only openings in size upto half the head dia. are allowed, for bigger openings, App. 14 is referred to.)
On taking a quick glance at App.14, I noted that this probably doesn't address bolted connecions, it is applicable only to integral connections.
1. Am I correct in my understanding of App. 14?
2. If yes, Can somebody please suggest other methods for evaluating reinforcement of such opening?
Starrproe
RE: Using Manway as Nozzle
You can design the flange as a ring flange per App.2 with an unusual proportion of A to B. Of course you'll get an also unusual thickness, but that's what the code would allow...
More usually you would use a flanged conical reducer.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
First thing, you have to make sure the Manway has been designed as a nozzle and not a manway.  Basically std wt plus corrosion allowance wall thickness.
As for cutting a hole in the blind, well, it would be much easier to use a 24 X 16 reducing flange and not worry about code calculations.
When it becomes a nozzle instead of manway, the connection flange becomes piping instead of vessel part.
