Victaulic vs Compression Fittings - which is better???
Looking for some expert advice on whether to use Victaulic's or compression fittings. It's for an enclosed heat exchanger skid with a max 400kPa pressure rating running 2" & 1" PE100 PN10 pipework between the system components.
Aim is to implement the most robust (ie. least maintenance) and most affordable option.
Any advice to help me decide would be very much appreciated.
Cheers
Cheers
RE: Victaulic vs Compression Fittings - which is better???
I think those joints advantages are in fast assembly.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
