Shaded solid with edges in another color
Hey
 Newbee here, can Pro-e display a shaded solid with the edges in a different color or any color that hightlites the edges?
Your help is most wecome.
Thanks, Dan
RE: Shaded solid with edges in another color
Hi:
 I found using View > Display Settings > Model display > Shade Tab > check box > With edges
The shaded model will display with contrasting color displayed edges. So is there a user defined edge color available?
Thanks, Dan
I was actually looking for a way to change the color of the edge lines just the other day.
Unfortunately we just had to settle, but would definitely be interested to hear the solution.
Couldn't even find a config.pro option
Chris Loughnane
http://www.pdnotebook.com
http://www.twitter.com/DesignNotebook
Make the complete model one color then select all the surfaces and make them a contrasting color.  You will get the effect you are looking for.
It should be easier.
That works pretty well but all your appearances will be completely matte (no shine).
