Trouble Making Variable Radius Fillet
I'm trying to get the edges of this hole to have a variable radius fillet. I need it to be 0.2m at the points where the rim of the hole intersects with the right plane, and 0.05m at the points that are perpendicular to the right plane.
The problem is, when I try to do it, I am not getting those points where I can set what radius I want. I think it has something to do with with the hole being slanted, but I might very well be wrong. It works with a constant radius fillet, but I need it to be variable.
I would GREATLY appreciate any help you guys could offer. thanks in advance.
RE: Trouble Making Variable Radius Fillet
Check the attached file.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
Thank you so much. I never would have thought to do that.
