Adding a symbol to a text sketch
Is there any way to add a symbol (diameter etc) to a text sketch same way as to an annotation?
Thank you,
Boris
Thank you,
Boris
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Adding a symbol to a text sketch
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
Alt + 0248 ø is lower case.
FYI
Christopher Zona - Product Designer
Loretto, Ontario
When should I hit Alt+216? When Sketch Text dialog window is open? Also, where can I find the character map?
Thank you,
Boris
character map is a microsoft program available mostly in all office products. one of the place is, open word -> insert tab -> symbols fly out -> more symbols.
Alternatively, within SW, For dia symbol, I can insert a separate text (Use font : symbol Use charector : f) This will bring the dia symbol
BT
~ BT
Copying from character map worked.
Boris
The "0216" must be typed on the number pad.
That code works. Where can I find codes for other symbols?
http://www.alt-codes.net/
http
ht
http://tl
http://www.youtube.com/watch?v=MZyFcFhS4QM
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
