Rev Letter in Revision Table
This is the first time I have ever had this happen in a drawing:
My revision table has 'A' and 'B' revisions rows.
When I 'Add Revision' the next row comes in as 'F' instead of 'C'.
Any suggestions of where it is pulling this information from or how I can correct?
I assume someone else modified the drawing and somehow changed something.
Thanks for the help.
RE: Rev Letter in Revision Table
I can insert a blank row.
type in 'C' in the revision column, and it inserts the correct symbols as rev C.
But if I do 'Add revision' again it still tries to put in 'Rev F' again.
The "next letter" for auto incrementing is in the Rev block table itself.  When we copy any drawing with a rev filled   to start a new one we always delete the rev block and insert a new table.  Maybe someone knows away to roll back besides deleting rows in the table.
What are the setting s in Tools > Options > Document Properties > Tables > Revision --- Alpha/Numeric Control ?
'A,B,C' is selected
'Change all' is selected/greyed out
If I select '1,2,3'
Insert a new revision row and Rev 1 comes in.
Delete Rev Row 1
Change back to 'A,B,C'
Insert new revision and it is now at 'D' as it should be.
I don't know what is going on, but will dismiss this as either a setting mixed up somewhere or a glitch with this file.
Thanks for all of the help.
Are you using PDMWorks? If so, change the setting from the vault to not use revision table.
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
Smart Revision tables are junk.  The quicker you realize this the better and less work you will have replacing rev tables in the future.  I tried them on a couple of drawings awhile back and realized their short-comings pretty quickly.
I just deal with it and over ride the rev letter as needed.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 4.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
I tried that as well then you end up having over half of your drawings not being automated.  You might as well just get rid of the automation that's bugged and use a manual table.
Hi, MDGroup:
What version and SP of Solidworks are you using?  I do not have this issue with mine.
Best regards,
Alex
I am on SW2009 SP4.1
This is the first time in 100s of drawings that I have ever had an issue with the 'auto-lettering' in the rev blocks.
Hi, MDGroup:
I think you opened a drawing document created with old version SW.  Revision "C", "D", and "E" were removed by someone with the old SW.  So, when you add a new revision, SW showed you next revision after "E", hence gave you a "F".  This issue does not exist in new SW documents with relative new version.  I use SW2008 sp3.1 and I do not have the issue.  You can alway fix it manually through "revision" custom property of the drawing document if this happens.
Good Luck!
Alex
