Friction Torque on Rotating Disk
I have been trying to solve for an equation that describes the torque created on a shaft as a result of friction between a mophead in rotating in contact with a hospital floor. Both coefficient of frictions are known, along with rotation speed(which as far as i gather is irrelevant) the diameter of the head is also known. Any help would be appreciated.
RE: Friction Torque on Rotating Disk
There should only be one coefficient of friction between the mop and floor, all affected by how wet the mop is and by the surface condition of the floor. A century old spruce plank floor would be different from a new, ceramic tile floor. Can you even assume that this is Newtonian friction?
The easiest thing to do might be to attach a wrench or vice grips to your mop head, and use a fish weighing scale to measure torque. You need to simulate the condition of the mop head as well as the contact force.
The next best thing would be to measure the linear force and calculate torque.
Torque = Force × Diameter / 2.
Just to clarify, you have the friction coefficient or the friction? If it's the coefficient then you need to multiply that by the normal force (how hard you are pushing the mob down onto the floor) to get the friction.
Take the double intergral over r and angle theta of
P*mu*r*dA
where P is the pressure (e.g. lbs/in^2) applied to the disc, mu is friction, r is the radius coordinate to any point on the disc.
In rotational coords, dA = r*dr/dtheta
Assuming P and mu are indepdent of theta and r (no steering forces applied, the torque is:
P*mu*pi*R3*2/3
Where R is the outer radius of the disc.
Or, where F is the normal (vertical) force applied to the disc:
Torque = 2/3*F*R
Torque=2/3*F*mu*R
where mu is the coefficient of friction.
And for best wrench yes i am looking into how much the normal force needs to be. The head is going to be interchangable so the floor can be mopped with a disenfectant first and then changed over to a buffer head to apply a antimicrobial polymer coating.
