Print Dialog - Zoom, Pan option not working
Is there a separate setting to activate the zoom & pan options on the print dialog. I find this very useful for me.
Does any one know how to bring these buttons to work?
Thanks in advance.
BT
Thanks in advance.
BT
~ BT
RE: Print Dialog - Zoom, Pan option not working
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
This dialog is a lot more different than any other print dialog. Right in the dialog there is zoom, pan change sheets etc. But few of them are disabled.
~ BT
Do you have an approved video card and driver?
Maybe a printer driver issue. Can you test using other printers?
Do other SW installs at your company have the same problem?
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
I discovered that these Icons are working if I am printing a part (not drawing). When a drawing is choosen a sheet # is displayed at the XXXX (see attached image)
I found a interesting feature, that are very useful in solidworks explorer. To quickly view & print files without check-out OR even open them in solidworks.
While on the sw explorer, select a drawing in the PDMWorks, go to the view tab to bring up the e-drawings view. By default this shows only the first sheet. There are no tabs for the rest of the sheets. we can right click and choose sheets->click on any other sheet number to bring it up.
~ BT
