Are there size limitations for use of WN & SO flanges?
In Section VIII, are there any size limitations set for the use of slip-on flanges where one must switch from the SO to a weld-neck, i.e. with manways?
I thought I remembered something regarding either size or service of a nozzle, and if it exceeds the given size or is to be used for that particular type of access or nozzle service, it cannot be a slip-on flange...but I could be wrong.
Aside from the temperature/pressure ratings in B16.5 as mentioned in UG-44, I cannot find any other type of limitation such as those mentioned above.  Can anyone confirm this for me?
Fitter, happier, more productive
RE: Are there size limitations for use of WN & SO flanges?
Section VIII, Div 1 accepts "standard" ASME B16.5 and B16.47 flanges as standard pressure parts, no calculations needed. B16.5 defines several types of flanges, including slip-on. B16.47 defines only weld neck type, it does not define the slip-on type. Thus it would seem that 24" would be the largest "standard" sli-on flange you can use. Slip-on flanges produced to other standards (API, AWWA, etc) would have to be analyzed with Appendix 2.
not the code, but service conditions may limit use of SO flanges as well as PWHT with out vents.
Tom:  gotcha.
Vesselfab:  I think I understand where you infer those limitations to be.
Thanks guys.
