Setting and keeping Work directory
I have been away from Pro-E for a while.  I am working with WF4 now and am wondering how you KEEP the working directory as the default after you change it?  Is this a config.pro command?
RE: Setting and keeping Work directory
file_open_default_folder working_directory
I usually work on projects for different clients at the same time, often in different versions.
Having an icon for each client ensures that I don't use WF4 for something that should be WF2. More relevant to your questions, if you right click on the shortcut and select properties, you will see a dialog box that says "start in".  Enter your working directory location and you shouldn't have to worry about your working directory or version again.
Chris Loughnane - Product Design
http://www.pdnotebook.com
http://www.twitter.com/DesignNotebook
Also look at the following config options
save_object_in_current no
override_store_back no/yes
Saves file where it was opened from and saves you from browsing to the directory.
Michael
