ASTM A283-C or A36?
ASTM A283-C or A36?
For storage crude oil (medium corrosive) which material should be use ASTM A283-C or A36?
As per API 650 both are may to used.
My question is what considerations to choosing or determining one of listed materials above?
Which material have susceptible corrosion A283-C or A36?
RE: ASTM A283-C or A36?
If as you post your crude is corrosive and there is some corrosion there will be no measurable difference between the two material in your service.
