Vacuum Column Overhead Design and Line sizing
Hi!
I have couple of questions regarding vacuum column overhead design:
1) How to calculate non-condensable gas for vacuum column overheads?
2) What is the criteria for sizing vacuum column overhead line?
I will really appreciate help on the questions above.
Prochem
RE: Vacuum Column Overhead Design and Line sizing
Question 1: See attached graph for vacuum air leak.
You also need to add any inerts normally in the process stream
Question 2. See attached table of velocity. The answer depends on level of vacuum.
prochem + Yitbos, in vacuum units you have to add the gas formed due to cracking (in the heater) to the air leaking in.
Cilliers
