migrate sketches from Nx2 to Nx5
I have a question to Nx2 to Nx5 geometrie migration.
We have created many parts created in nx1 and nx2 years ago. Those parts are in strong in reuse.
The sketch visualation behaviour was changed in Nx4- Sketches new created in Nx5 are shown in object color - editing nx2 skteches shown in sketch line color -nx2 behaviour. Is there a way to migrate the nx2 sketches to Nx5 behaviour without recreation?
thx in ad
thx in ad
RE: migrate sketches from Nx2 to Nx5
Now if the question was how do I change a Sketch curve's color to an object color instead of Sketch colors, then while outside the sketch task, select the sketch curves and use...
Edit -> Object Display...
...change the object color (which will have no effect on the colors used when the Object Color option is toggled OFF).
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
In my attached pic you can see mixed version sketches in assy context.
Customer Defaults -> Sketcher -> General -> All
...or it can be overridden at...
Preferences -> Sketch -> General
...but you have to be in the Sketch task for you get access to this option. You can also un-hide the Display Object Color toggle on the Sketcher toolbar inside the Sketch task and control it from there.
If your question was how do you upgrade an old sketch to the latest color scheme, you can do that by going to...
Preferences -> Sketch -> Colors
...and selecting the 'Inherit from Customer Defaults' button, which will upgrade older sketches to the latest color standards.
If this doesn't cover what you're looking for let me know, but please be very specific as there are many issues dealing with sketches and colors so we need to make sure we're both talking about the same thing.
John R. Baker, P.E.
Industry Sector
Cypress, CA
try to follow me...
the sketches are in a def part buttom up thinking.
We are in context of the assy the sketches to be linked are
shown in the entire part references set
Sketches created in nx2 are shown in the cyan in this case not the object color of the sketch(grey), newly created sketches are shown in object color grey of the sketch.
This behaviour as I know was introduced in NX4 -
The color standard was not touched - in the seed part -
reused from nx2 to nx5 (cdf included).
What to do to get the same visualisation of the sketches maybe to get back the old look?
thx so far
One thing to keep in mind, when working 'in context' the Displayed Part controls the appearance of the objects, not the Work Part.
John R. Baker, P.E.
Industry Sector
Cypress, CA
open the volume.prt and examine / here it not grey it green
- an example for this issue
It would appear that when an Assembly/Component/Sketch scheme like your example is first opened, that for some reason, when working 'in context', that you see the sketches AS IF they were set to display their 'Object' colors even though when you go to the actual Part file, that option has NOT been toggled ON.
Now I did discover a rather strange behavior in that if while working 'in context', AND ONLY while working 'in context' (the part with the sketches is the Work part and the Assembly is the Displayed part), if I were to EDIT EITHER one of the sketches (even if all I do is simply enter the sketch task and then immediately leave it), that when I return the assembly to be BOTH the Work and Displayed part (I'm NO longer working 'in context'), that the appearance is NOW correct (it matches what you would see if you had made ONLY the part with the sketches the Displayed part). Now you might think that this as 'fixed' the behavior and that saving to the parts will make it all right. Sorry, but saving the files, and the closing them, the next time they are opened, we're right back where we started.
As to what's causing this, I can't really say, but I suspect that it has something to do with not being able to properly pass the display criteria from the Component part to the Assembly part when it's first opened or at least not until the Sketches are forced to be fully loaded, WHILE WORKING IN CONTEXT, by editing them in context.
Now I could open a PR and see what development has to say about this but since this appears to have been the default behavior for some time now I suspect that they will not put a very high priority on this since it a doesn't cause any real harm, other than not seeing the sketch colors properly when working 'in context'. If I do open the PR, I'll pass along anything I learn.
BTW, I don't think this has anything to do with whether the Sketches were created in NX 2.0 or NX 5.0, or ANY version for that matter, since when I looked at your sketches, sketch_000 was created with objects which are 'Cyan' while sketch_001 was create with object which are 'Pure Green' (which is how they are seen 'in context'). One thing I did learn is that with NX 7.5, when you ask to list the information about an object, BOTH the 'Color' (AKA Object Color) AND the 'Display Color' of the object is listed, whereas prior to NX 7.5 only the 'Color' (AKA Object Color) was listed. This may indicate that development is aware of this unexpected display situation and while have not yet fixed it, they are at least providing more information about the colors of the object, both actual and displayed, which might help users to at least better understand what's happening, if not exactly why.
As I said before, I can open a PR if you would like me to follow-up or not, just let me know, OK?
John R. Baker, P.E.
Industry Sector
Cypress, CA
would be nice if you do the call. In most cases ( BTW there was no in this case) I get them back ...closed - with works as designed - I'm tired doing calls
Anyway, if I learn anything, I'll pass it along.
John R. Baker, P.E.
Industry Sector
Cypress, CA
We tracked down the problem and it has been fixed. However, since there are workarounds and the behavior does not prevent a user from doing his/her work, the fix is only being submitted to NX 8.0.
John R. Baker, P.E.
Industry Sector
Cypress, CA
