Pivot friction equation of a ball and socket
Looking for a torque equation for a friction pivot of a ball within a spherical socket. Ball shaft to remain normal to socket horizontal axis and ball shaft assemby is to rotate in the horizontal plane. At most 1/2 (but necessarily) of the ball may seat in the socket. Shaft rotation is slow at at most 1/2 a turn.
RE: Pivot friction equation of a ball and socket
in the same direction as the shaft.
isrealkk, I was aware of your equation, howvever,I was under the impression that it was for a cylindrical surface such as a journal. Nonetheless, I'll use it
Also you might want to look at a rod end or spherical which could get you in the ball park or maybe in the game.
http://
http://www
