SW 2009 Lighting
SW 2009 Lighting
SW 2009 Lighting
So what is up with lighting in 2009.  I have just been upgraded from 07.  I can not move/modify light position, color or intensity.  I am not able to RC to bring up properties box either.   Did i get a bad install???? Anyone else experiencing this issue.
Jay
RE: SW 2009 Lighting
In 2009 RealView graphics kind of took over a bit.  Do your preset scenes work?  Do you have PhotoWorks added-in?  What's you graphics card?
Dan
www.eltronresearch.com
Dan's Blog
Go to Tools\Options\Feature manager and turn your Lights, Cameras, and Scene to Show instead of automatic.
Then you will see the folders you used to see and will be able to control the lights etc...
Hope that helps answer your question.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
Eltron - Yes PW is loaded and added-in.
Sbaugh - This resolved the issue.  now i have access to the folder and can manipulate items as needed.
Thanks to both of you for your quick comments, much appreciated.
-Jay
