Meshing Multiple Parts
I have a geometry imported from Proe to workbench12. This geometry has multiple parts with varying sizes. I was wondering if there is a way to mesh each part separately or control the mesh on each part.
Thanks.
Thanks.
RE: Meshing Multiple Parts
if you choose the "Method" from "Mesh Control", it generates "Automatic Method" in the mesh tree. With this option you can select the parts and set up your mesh.
regards
