NX7 Postbuilder Errata - Corrupting Post
NX 7, Win7 64, Post-builder.
Problem: empty custom command with number as name causes post to fail to load after it has been saved and closed.
Steps taken to produce problem:
1. Create post
2. Program & Tool Path -> Custom Command
3. Create a new custom command
4. Leave command empty
5. Name the command/procedure: PB_CMD_2
6. Save
7. Close
8. Load post
9. Post fails to load
Work-around:
Manually edit TCL file to change the custom command. (Edit contents, add valid command inside custom command (not a comment)).
Post-builder is unstable after this error occurs and advise to restart.
Post should load again - advise deleting command
