Can't locate the HELP files
I would like to spend some time at home studying the CosmosWorks help files. Is there a way to export or save these files? Aren't they just html files? I can't even find the files.
Kevin
Kevin
RE: Can't locate the HELP files
Else search for Compiled HTML Help file. The help files should be under help folder in the CosmosWorks/SimulationWorks installation folder.
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
I'm not to familiar with the .chm format. I guess I'll just copy the files and try opening them at home.
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
http://help.solidworks.com/
~ BT
Simply copying the CHM files worked fine.
BluTurtle - I didn't see the CosmosWorks help files online like you suggested.
Here is the Simulation link.
~ BT
