Design load for industrial walkways
We are making steel walkways - steel grating supported by steel channels.  Nothing out of the ordinary, just personnel accessing valves and getting over piping.  Is there a required design load for these structures?
RE: Design load for industrial walkways
At least 25 psf minimum.  Some people use 60 or even 100 psf depending on anticipated loads.
Thanks, MIke - I'm looking for a reference to document the loading used for our design - is the 25 psf OSHA, ASCE, IBC, etc?
ASCE 7-05 says 40 psf / 300 pound concentrated for "Catwalks for maintenance access" and 60 psf for "Walkways and Elevated platforms (other than exit ways).  Now all I have to do is determine if these platforms are catwalks or walkways.
Now this is interesting - further into ASCE 7-05 in table C4-1 Catwalks are listed for 25 psf live load.  My previous post referenced Table 4-1
25 psf comes from the OSHA standard on "light weight" loads for scaffolding.  I generally interpret that to mean just a couple of guys walking around.  Be sure to check for a concentrated load of 250 lbs per guy - again another OSHA assumption.  A 250 lb boilermaker would be considered a lightweight.  Those guys soemtimes go 350 plus!!  Once had a 450 lb technician wanting to get on my already built scaffold to inspect an airplane.  I said NO WAY!!
I like 50 - 60 psf - usually doesn't really affect your design or cost that much and you can sleep nights.
I think I'll use 60 psf per ASCE 7 for walkways and elevated platforms.  Thanks for you help and advice.  This is a good board to bounce ideas off of.
