care about shaft misalignment...?
shaft misalignment on transmiting power cause energy loss beside of premature demage on machine parts.
shaft misalignment cause bad friction in transmiting system such as flexible coupling.
this phenomena cause relative motion between driving shaft and driven shaft and reduce the rotational speed (rpm).
Power(P) = T.n......
in this case is just speed reduction only,..? how about torque,..?
can u give me explanation or reference to solve this problem,..?
thanks,....
thanks,....
RE: care about shaft misalignment...?
Ensure your machine and drive are correctly alligned. Have a look at Rexnords 'Magnalink' it is a noncontact coupling that transmits the torque via magnetic force.
Greg
Alignment is a key issue, but during operation unavoidable deflections/misalignment usually occur and that's where a coupling's design and properties stand out (or fail).
Define the application a little and maybe someone can help out.
Brian
