Teamcenter error "No instances were found with the given name"
Can anyone please help!!!!!
We are currently using Ideas and are switching over to Nx 6. We are using Teamcenter as our data managment system. The problem that I am having is that when I check in a part or assemblie going from Rev 'A' to 'B' the BomView Revision is staying checked out for revision 'A'. I have tried to check it in, and have also tried to Cancel the Check out. It always gives me an error "No instances were found with the given name". does anyone have any ideal as to why this error could be happening?
Thank you for your time,
Curtis Farr
