Chinese steel and European Standards
EN 10305-5:E220,EN 10130 : DC01AM and EN10025 : S255JRG2 or J355JRG3
how does this compare to the Chinese Q235?
I understand Q235 is comparable to 1020 steel, what does that mean in respect to the above Standards?
RE: Chinese steel and European Standards
According to my reference below,
Q235 is under T13788-2000, which is a cold rolled ribbed steel bar specification for the reinforcement of concrete...
E220 is under a specification for steel tubes for precision applications...
DC01 (no AM) is under multiple specifications
EN 10270-2
EN 10130 for cold rolled low carbon steel flat products for cold forming...
S255JRG2 I believe should be S235JRG2, is under specification EN 10250-2 for open die steel forgings.
or J355JRG3. I have no current listing. There is an S355JRG3 under the same specification above (EN 10250-2).
As you can see you have various product forms. Chemical composition ranges were listed but I did not want to list them because of time and space.
If you want to compare, obtain the necessary specifications mentioned above and review them for a proper comparison.
Source; Stahlschlüssel 2007
thanks for the above. I am trying to determine if steel to standard Q235 (T13788-2000) is suitable for applications that specify E220. Any suggestions?
