Is it possible to offset Curves/lines in ANSYS?
Is there a command/macro to offset lines in ANSYS? By OFFSET i mean the keypoints should move normal to lines to the specified distance. I know LGEN works for straight lines and circular arcs but what about other irregular curves? (Its cumbersome to find the centers of every segment and use LGEN)
Nodal.
Nodal.
RE: Is it possible to offset Curves/lines in ANSYS?
Thanks bobby. But i using the classic ansys version 12 and i am looking for any commands/macros that can do the job.
nodal
or do you mean something different?
www.priamengineering.co.uk
nodal
