ASTM E8 and 316L
ASTM E8 and 316L
For ASTM A240 thick, hot rolled, annealed plate UNS S31603 (316L)
What material issues may cause a properly run ASTM E8 to report an estimated Elastic Modulus (Youngs) significantly lower than expected? (28-31Mpsi)
What testing issues may cause a good piece of material to show a very low modulus? How common is this?
Looking at the shape of the developed stress-strain curves, what can one tell to help explain a large deviation in modulus?
Yield and Ultimate strengths are within spec. Chemistry and Hardness are nominal.
RE: ASTM E8 and 316L
Plymouth Tube
