Multi-step structural simulation -- Is it possible?
Does anyone know how to do a multi-step structural simulation in COSMOS? Essentially, I want to deflect a beam into a pre-loaded state, and then push on it in a different direction. I've done similar multi-step simulations in Abaqus, but can't seem to find the functionality in SWX/COSMOS.
One work around would be to deflect the beam to the pre-loaded state, and then save the resulting deflected beam into a new body, and then run a second analysis on the new body. The trouble with this is that the stress-state is not saved with the new body, and so the second analysis essentially assumes the beam was originally formed into the deflected shape with zero residual stress...
Andrew
Nuventix
Austin, TX
Andrew
Nuventix
Austin, TX
RE: Multi-step structural simulation -- Is it possible?
-Andrew
