AutoCAD file format versions
All,
Is there any way to tell what version a dwg file is saved as without having the higher version? I'm using AutoCAD 2006 and lately when I've tried to open files from a couple different sources I get a message stating "Drawing file is not valid". Just wondering if it's time to get an upgrade and if so what version I would need to jump to.
Steven
Steven
RE: AutoCAD file format versions
- From ht
•AutoCAD DWG Version History by Release for the past 25+ years
The first six bytes of a DWG file identify its version. In a DXF file, the AutoCAD version number is specified in the header section. The DXF system variable is $ACADVER.
•AC1024 AutoCAD 2010
AC1021 AutoCAD 2007/2008/2009
AC1018 AutoCAD 2004/2005/2006
AC1015 AutoCAD 2000/2000i/2002
AC1014 Release 14
AC1012 Release 13
AC1009 Release 11/12
AC1006 Release 10
AC1004 Release 9
AC1003 Version 2.60
AC1002 Version 2.50
Civil Development Group, LLC
Los Angeles Civil Engineering specializing in Hillside Grading
http://www.civildevelopmentgroup.com
