control of flash rusting
We have a large area of carbon steel to clean down to bare metal.  Due to conditions,  we will be removing scale, rust, and coating to bare steel and then wait up to a week to apply the coating.   Conditions are damp and cold , no sunlight.   Is there a temp coating/ application I can use to prevent/reduce flash rusting?
Would like to apply as I go. Then in a week come back and remove by solvent or other chemical method the temporary coating and expose the bare steel again?   Not a lot of restriction on chemicals but the 1 week delay is unavoidable. Thanks
RE: control of flash rusting
Henkel, Houghton and Castrol all have products that will work. Do a Google search. You could also look at products, like LPS, available in retail outlets. You want a water displacing product, preferably solvent rather than water base.
