ANSYS Workbench V12 Shell Meshing
Does ANSYS Workbench have option of mid-plane shell mesh or surface shell mesh similar to COSMSOWorks?  If so, what are the steps using GUI?
RE: ANSYS Workbench V12 Shell Meshing
When you use mid-surface and while meshing, select src/trg selection to automatic or manual thin, ANSYS GUI will give you an option between solid and solid shell element. Also try to search about src/trg in ANSYS help for more info. Hope this helps.
