Can't see my Enhanced Attribute Editor
When I double click on my blocks with Attributes(Title, Revision, etc...) The Enhanced Attributes Editor does not appear on my screens, it is there as I can make changes, as I see the changes in the block. I either have to fly blind witht he tab button and save changes when prompt on exit change the attributes through properties, both sre PIA and time consuming.
Any help would be greatly appreciated.
BTW this is only happening with my profile other users can use the same station and not have the issue.
RE: Can't see my Enhanced Attribute Editor
Modify > Object  > Attribute > Block Attribute Manager....
or at the Command prompt, enter BATTMAN
hope this helps....
cherrypicker,
Thanks, although I have been through the help and have tried every command they offer that deals with the enhanced attribute editor, and none so far have lead me to a solution to my issue.
There are no boxes I can check or uncheck, that I have found, that will allow me to see the enhanced attribute editor. I can work in and make changes to my blocks w/ attributes, also I can see the changes in the block. it is like the eattedit command is invisible on my screen.
Is attdia set to 1 (one)?
Ralph
Structures Consulting
Northeast USA
RHTPE,
attdia was set at 0, I changed it to 1with no changes.
Thanks for the idea. it has given me some other avenues to explore in help
xxxDIA cover a multitude of dialog boxes, with xxx replaced by the appropriate topic (like ATT for Attribute).  1 (one)turns them on, 0 (zero) turns them off.
Ralph
Northeast USA
Nate 966, for curiosity sake, which ACAD version do you have?
Chicopee,
I'm running AutoCAD 2009 on a 64 bit Vista Business OS.
With a Nvidia Quadro FX 1700 graphics card. and this is the second graphics card I have tried, as the original to the computer was not capable of handling AutoCAD or Solidworks.
