older bridge seismic guides for single-mode analysis examples
Does anyone know of a weblink or site to find a pdf (preferably) of either of these two older bridge seismic guides?:
(1) Guide Specification for Seismic Design of Highway Bridges, AASHTO 1983.
or
(2) Seismic Design Guidelines for Highway Bridges (ATC-6), Applied Technology Council, 1981.
The AASHTO LRFD Bridge Spec references the two under Single-mode spectral analysis as containing examples. The examples are what I am looking for.
civilRoo
or
civilRoo
RE: older bridge seismic guides for single-mode analysis examples
You could try contacting
http://mceer.buffalo.edu/
or AASHTO. However, the older documents are not readily available from AASHTO.
I would also recommend the NTIS, National Technical Information Services as where most of the government publications are from. Here's a link: http://www.ntis.gov/
Also, I seem to recall the older AASHTO having a single mode example in it too as part of the commentary. Too many piles of junk to check for certain.
Hope this helps.
![[pipe] pipe](https://www.tipmaster.com/images/pipe.gif)
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Do you still need it?
