Knockout drums
Knockout drums
Knockout drums
I am a buyer in the Fossil Power Plant industry.  I am having trouble locating manufacturers for Fuel Gas Heater Knockout Drums.  From what I understand, they are a kind of Vapor separator, with water removal from natural gas, prior to it going into the Combustion(Gas) Turbine.  I have received numerous "No Quotes" on this.  Is there anyone who knows of a supplier(s)?
Texpack
RE: Knockout drums
Based on your name Texpack, I assume you are in Texas?
Contact ACS Industries - Houston, TX
Koch Glitsch - Houston, TX
These will provide removal of aerosols to the 8 um level or so.
You can also utilize a filter coalescer to remove solids & aerosols down to the submicron level.  This is more appropriate if you are feeding LoNox burners or Ultra LoNox burners that have small burner orifices.
You can send me a message if you have more questions.
RE: Knockout drums
Actually I am from Florida, I made up the name Texpack some time ago.
Thank you very much for your input, I will contact the suppliers.
RE: Knockout drums
You can try Pall Corporation for the Filter/Coalescer style separator.  They do a great deal of work in power.
RE: Knockout drums
You might also want to contact Midwest-Imperial Steel Tank Fabricators in Frankfort, Illinois. 815-469-1072.
