Welded Moment Conn Backing Bar
Involved in a project in a non-seismic region with field welded (CJP flanges) moment connections. Erector is using backing bars and wants to leave them in-place. I see a lot of information saying this is not permitted for seismic or fatigue conditions but is it acceptable for a non-seismic moment frame system.
RE: Welded Moment Conn Backing Bar
This is also why rough, flame cut access holes are prohibited in fatigue applications. Each notch is a focal point for local stress. The risk of fatigue, as a mechanism for failure, increases as the stress in the metal increases, beginning at around half of yield.
Keep in mind that welding without backing requires a higher level of qualification than welding with a backing.
Most often, rejectable weld anomalies occur at the root of a CJP weld. These are most commonly lack of penetration and poor fusion. While other anomalies may occur (inclusions, porosity,etc.), these are common.
The seismic specification, section 11.2a, says the same thing for the cases where the backing bar is removed.
