STAR Error Message in Simulation
Has anyone encountered an error message stating that "STAR has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
This is only happening when the Global Contact is set to "No Penetration" while trying to analyze an assembly. It will run when the contact condition is set to "Bonded", but this is not the correct condition.
Appreciate the help.
RE: STAR Error Message in Simulation
forum1183: SolidWorks: Simulation/FEA (COSMOS)
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
