Getting weight from model to drawing
When retrieving the weight from the model to the drawing I have used "physical properties" and "mass" when editing the title block. It works nice, but I get more decimals than I want. Typical 3,42kg. When changing the documents setting to less decimals I get less in the title block. However I want to use 2 decimals in the model. Is there any other way to reduce the decimals displayed in the drawing?
