Ductile Iron and Flammable Hydrocarbons
Is ductile iron objectionable for use in a pump bowl pumping flammable hydrocarbons ??
My perception is that ductile iron is deligated to somewhat non-hazardous applications such as water or water based fluids.
RE: Ductile Iron and Flammable Hydrocarbons
If you have a hydrocarbon processing facility with a serious enough fire to really heat up that pump, I'd tend to think that there are bigger issues at hand but I can see where they're coming from.
Genrally speaking, any service where cast iron is acceptable, ductile iron is also OK.
I suggest that you contact the Manufacturer.....they can tell you if they have lots of DI pumps in hydrocarbon service
-MJC
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
