How to write the statement for MAX and MIN safety margin?
How to write NASTRAN statement for output of safety margin:
MAXMIN (DEF) TTTT (BEAM,10) MAXALG(10) MINALG(10)?
I know the how to write the ourput for stress and forces but don't know which word in NASTRAN is used for safety margin (replacing TTTT in the above statement). I tried to find it in the manual but could not.
Thanks!
RE: How to write the statement for MAX and MIN safety margin?
Dear alin09,
Conventions for BEAM elements:
• M.S.-T: Minimum margin-of-safety in tension.
• M.S.-C: Minimum margin-of-safety in compression.
• Minimum M.S. found over entire length of element
Definition of Margin-of-Safety (M.S.):
The M.S. in tension is: M.S.–T = (ST / S-MAX) – 1.0, where ST is the tension allowable given on the MAT1 entry and S-MAX is the maximum stress given in the output, S-MAX = max (SA-MAX, SB-MAX). M.S. in tension is computed and printed if and only if ST is greater than zero and S-MAX is greater than zero.
The M.S. in compression is: M.S.-C = (–SC / S-MIN) - 1.0, where SC is compression allowable given on the MAT1 card and S-MIN is the minimum stress given in the output, S-MIN = min (SA-MIN, SB-MIN). M.S. in compression is computed and printed if and only if SC is greater than zero and S-MIN is less than zero.
The output I have using FEMAP & NX NASTRAN 7.0 is the following:
                                  S T R E S S E S   I N   B E A M   E L E M E N T S        ( C B E A M )
                    STAT DIST/
   ELEMENT-ID  GRID   LENGTH    SXC           SXD           SXE           SXF           S-MAX         S-MIN         M.S.-T   M.S.-C
0         1
                  1   0.000   -4.220390E+03 -4.220390E+03  4.220390E+03  4.220390E+03  4.220390E+03 -4.220390E+03  3.7E+00  6.1E+00
                  2   1.000   -3.798351E+03 -3.798351E+03  3.798351E+03  3.798351E+03  3.798351E+03 -3.798351E+03
Best regards,
Blas.
Blas,
Thanks for the reply.
I know the meaning of margin of safety and how to calculate. But I don't know how I can get the first 10 maximum and minimum values of margin of safety by using the statement MAXMIN (DEF) TTTT (BEAM,10) MAXALG(10) MINALG(10) in NASTRAN input file? What do I use to for "TTTT" to represent margin of saftey?
