Import big assemblies from Soid Edge directly or by parasolid
I need ro translate data from Solid Edge .They are big assemblies with thoudsans of parts. It works very well to open directly original sub-assemblies.
 I'm not able to open the bigs one : sub-assemblies second level  and the general assembly. I tried with parsolid but it is to big (103 MB)  and computer crash after try to rebuild hundreds of assemblies (finally empty). Now I have almost all sub-ansemblies and parts but not general and second level ones.
I need a tip how to deal with this kind of problem.
RE: Import big assemblies from Soid Edge directly or by parasolid
With UG, I've had better results importing parasolid than direct.  Haven't tried SE.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
Are you using a x32 or x64 bit operationg system?
I suspect you are running out of system resources (memory) if you are crashing out of SolidWorks on a x32 bit system.
Cheers,
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2010 SP2ev, Windows 7
http://www.solidmuse.com
http://www.phxswug.com
Hi Anna,
 I think your right. I have this message when I try open parasolid file. I use 32bit.
What it will be the approach to this problem?
Petrino
Get a x64 bit OS system and more system memory.  Or have someone else with an x64 bit system open the files for you.
Cheers,
Anna Wood
