Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very happy with the whole site and would like to extend my compliments to all of you who work to make it one of the most useful sites (If not THE Most Useful) ...and the easiest to navigate..."
Geography
marantinj (Chemical)
26 Jan 10 17:03
We will be producing HCl off gas from a chemical reaction (approximately 8.3kg/h).  In order to dilute this, it will first go through a water rinse of 55kg/h to get it to 15% solution.  I will need to determine the pressure which arises from this system.
Thereafter, the diluted HCl will go through a caustic scrubber (20% NaOH).  I will need to determine the heat of this reaction as well as the pressure produced.
Can anyone help with this?
Chance17 (Chemical)
2 Feb 10 14:41
HCL solutions begin to "fume" (boiling point) at 28%.
So if you absorb HCL into a 15% solution, the HCL vapor fraction will not generate pressure.
The main heat effect in the caustic scrubber is the physical "heat of dilution" for NAOH.
These data should be available from many sources.
You would likely see a moderate temperature increase.
There is no significant pressure generation so long as the temperature is below 212-F.
The HCL also has a heat of dilution but at 15% the heat is small.
bimr (Civil/Environmental)
3 Feb 10 13:27
I agree that is just a heat of reaction question.
If the resulting temperature rise is undesirable, all you need to do is add additional dilution water which will take away the heat generated by the reaction.
Since this reaction does not need to be contained, there is no pressure generated.
Close Box
Join Eng-Tips® Today!
Join Us             Close
