blend colors on a surface
I have a 6" x 6" flat plate. I would like the left half to be red and the right half to be blue. I also want the two colors to blend in the middle, not just go from red to blue. Is this a function in solidworks colors or rendering?
RE: blend colors on a surface
You can achieve your desired results using the lighting functions in Solidworks. 'Lights,Cameras,and Scene' folder (I think Photoworks needs to be active)
Add a Spot-Light to one side with red lighting and a Spot-Light to the other with blue lighting.
See attached images.
It takes a lot of playing around with the different values to get the effect you want.
Good Luck.
Try the attached file and find out.
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
Dan
www.eltronresearch.com
Dan's Blog
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
