Sheetmetal Question
Sheetmetal Question
Hello all,
I have a simple sheetmetal part with 2 bends. I need to make a left hand and right hand version of it so I opened a new assembly with the left hand part, did a mirror (no merge) and checked the box for right hand and saved that part to its own file. When I went to make a drawing for the right hand part it does not have a flat pattern available. Is there a way to have the left hand/right hand parts associated and to have flat patterns for both?
BB
BB
RE: Sheetmetal Question
If I understand your question correctly, you are almost there.
In the 'Mirrored' part file, the new part should be a single feature with just a solid body (it is not a sheet-metal part yet, so no flat pattern)
You just need to select 'Insert Bends', select a fixed face, and enter your parameters.
It should now make it into a sheet-metal part with its own flat pattern (yet still linked to the original if changes are made).
Hope this helps.
You were exactly right! Thank you for your assistance.
BB
Occasionally you might get error flattening the mirrored part. You might have to open up the bend reliefs to get them to flatten.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
If rather than a mirrored part with a limited feature tree, you want to make a "save-as" part by reversing the direction of the sketches, make sure you check the side of the sketch the material is thickened on in Base-Flange1. This can bite the unwary.
regards, Diego
