LF>Book [Rope bridge mathematical design]
I am looking for the best Book that shows you step by step how to design or calculate a rope bridge.
I would appreciate your help if you know a good book.
Thank you
S.A
RE: LF>Book [Rope bridge mathematical design]
I'm not sure such an example exists.  You may want to investigate a text called Cable Structures by Max Irvine, which would be the closest to providing the theory behind the rope bridge.
Qshake
pipe
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
I have also an around  100 pages beautiful excerpt by Thomas C. Kavanagh on suspension bridges in my closed cabinet that I access only sometimes a year ... try whilst to identify and find.
Bridges to Prosperity is a charity that has a great website. They erect bridges on poor areas, and their website has a number of resources for the design and construction of simple suspension bridges.
They also have links to other resources, I seem to remember the webpage for the Nepal trail bridge program had quite a bit of information
http://www.bridgestoprosperity.org/
good link kelowna.
You need the design loadings and a non-linear analysis, as the deformation affects the cable stress.  Determining a reasonable initial sag is the starting point.
HTH
VoD
