Calder ERT (Desalination Process)
Folks,
Is anyone familiar with the Calder Energy Recovery Turbine? Specifically, model no. RO-300-100-4? I'm trying to interpret the performance curve for it, however it's not labelled properly and I can't determine what its giving you. All I know is that Flow is on the Y-axis and Pressure on the X. There are 7 curves, im guessing at different speeds, but they dont tell you what those speeds are. Is anyone familiar with this device and its curves?
RE: Calder ERT (Desalination Process)
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
It almost looks to me that it's the set of curves to derive the efficiency derates, based on speed (Y axis) and pressure (X axis).
But I'm no ERT expert, so I could be way off base.
