Patran PCL command to play .ses from the command line
Hi, I would like to play a .ses file (my script)directly from the Patran command line without using the menu File/session/play.
Does anyone knows how to do it? I do not find anything in the manuals.
RE: Patran PCL command to play .ses from the command line
I think you should do it once by doing the command from File/session/play.
then you open the current session file and copy the pcl command.
Onda
That is what I tried first but the patran.ses file does not show the command.
thanks
try with this command:
sf_play ("filename")
Onda
I find it, just write
!!input name_of_the_session_file.ses
and it works
thanks
Both are working:
!!input name_of_session_file.ses
sf_play ("name_of_session_file.ses")
Onda
Yep, thank you!!
