Stress in component crossection
Hello
I have a question regarding how to display the stresses inside a specific cross section of a component in SolidWorks Simulation. I have only been able to find the min and max values of the component using the plot tool.
I have tried using the section cliping tool to position my crossection but I can´t probe the stresses on the cross sectioned area.
The cross section I mentioned is in across a bolt hole.
Thanks in advance
Thanks in advance
RE: Stress in component crossection
My workaround to this problem was to split the model up into two sections with the interface on the plane you want to probe the result. As long as you set the contact condition to 'bonded' it will behave as a single entity. This allows you to probe the nodes on the section you desire.
Hope this helps
James
Also if you have the pressure vessel module you can pick a line through the solid and linearize the stresses.
