PROGRAMMABLE AC/DC ELECTRONIC LOAD MODEL 63800 SERIES
Does anyone have a clue on how to generate a 5th and other harmonic currents with the above mentioned current generator? The user's manuals and technical support have not been of great help. The intent is to generate the 5th and other harmonic currents to test how a given power meter performs in an electrical power system (120/240 Volt service) with such said harmonics.
RE: PROGRAMMABLE AC/DC ELECTRONIC LOAD MODEL 63800 SERIES
Alan
"The engineer's first problem in any design situation is to discover what the problem really is." Unk.
You mention current generator, this test device is labeled as a load and will not source 300 Hz current.
Can it only be programmed for constant power or constant resistance? That's the usual function of these loads.
We use Dynaloads at my workplace but i don't recall any of the technicians trying to work with harmonics on it.
Jim
ht
