Platen Design
Platen Design
Hello everyone,
I am a recent graduate and working at my first job. As my project I am in charge of a platen structure design. As for how it is stacked up, from bottom up, it is a .5" steel contact plate, then a 2.5" al. heating plate, with cartridge heaters inserted through it, then finally the insulation/cover attached to a top frame. Right now, the current design has this all bolted down with 1/2" bolts. In my opinion, the heat is causing the contact plate to have local deformities due to the bolts not allowing for the platen to expand with increasing temperature (400+ deg F).
If I am correct, I was going to increase the size of the clearance holes and use PTFE washers to allow for the bolts to slide with the expanding plate. What do you guys think?
Thank you in advance for any help given.
David
David
RE: Platen Design
RE: Platen Design
