how to calculate the seismic load of CMU screen wall
I have a 12" CMU wall (solid grouted) with 13.3' high. it is a screen wall. the verical reinforcement is #6 @ 18" OC
 I have calcualted the SDs=0.61, SD1=0.58 (design spectral response).
How to calculate lateral seismic load?
RE: how to calculate the seismic load of CMU screen wall
Are you sure of the reinforcing?  Usually CMU reinforcing is on an 8" module.  I would expect 16" on center.
Just use the pertinent IBC equations for the lateral seismic forces.
Mike McCann
MMC Engineering
Motto:  KISS
Motivation:  Don't ask
Agree with Mike on the spacing-See ASCE 13.3
See 12.11.1 of ASCE 7-05.  Apply force indicated as a lateral force at center of wall mass (0.4SdsI).
yes. it is 16" OC.
in the formula 0.4SDsI, is that I can be same as the adjacent building.
Thanks.
When I do seismic calcs on a cantilevered fire wall or screen wall, I break the wall into 4 quadrants of height and run the numbers as a 4 story building. I beleive this is conservative but it helps in the p-delta calc and the top heavy nature of a tall cantilevered wall.
